+8 manifolds
+8 manifolds
Does anyone have use for a pair of +8 exhaust manifolds and downpipes of early eighties vintage? Old but serviceable. For collection near Cheltenham or other arrangement.
- Phill Thomas
Re: +8 manifolds
Try Tim Ayres
Re: +8 manifolds
Serviceable maybe but i wouldn't say Tim Ayres is old!!!
Re: +8 manifolds
Thanks Tim, but I'm now drawing state pension!
Bruce, are they cast iron or tubular?
Regards from the Fiddleford retiremant home,
Tim Ayres.
Tim Ayres.
Re: +8 manifolds
I have a pair of early +8 Moss box Manifolds (cast iron ) with some fairly new stainless down pipes and balance pipe the ones that go through the chassis . But when I fitted them to Gizzard I had to re cut the holes in the chassis and weld up the old holes
Although I was assured that they were correct and would fit !!!!!!
So you would probably have to try them first
if you want ppm me with an address I can send them
- Andy Green
Re: +8 manifolds
Interesting are you allowed to modify the chassis
Re: +8 manifolds
Gizzard has never raced in the Series ....Next??
Re: +8 manifolds
Hi Tim,
They are tubular-standard +8 from that era exiting through the wing valence.
Re: +8 manifolds
Sorry Bruce
I misread your original posting I thought you were looking for some .
Re: +8 manifolds
Thanks Bruce,
It's possible I will have a use for them in the future so I may as well be the new custodian.
Can I collect them on Sunday 2nd November on may way back to Dorset from Leicestershire?
Regards, Tim.
Regards, Tim.
Re: +8 manifolds
Hi Tim,
have PM'd you
Bruce
have PM'd you
Bruce
Re: +8 manifolds
Sorry Bruce,
Haven't received your PM. I've recently changed one of my email addresses so would you mind re-sending it to: newelms@btconnect.com
Thanks, Tim.
Thanks, Tim.
